Idle down and check engine light comes.
1.1K views 2 replies 2 participants last post by  Wolfe99
So had to take the gas tank out , to pull the 4x4 actuator out so I could change the speed sensor . Since I put it back together now when you come to a stop the machine will idle down to 1300 rpm then the engine light comes on. The it goes back to 1500 rpm at idle. Then we you take off the engine light goes off ..
#2 ·
Leaking gas or kinked line from taking the tank out?
