21 - 40 of 67 Posts
Are the RPM kits better than the kits from EVO? I’m one of those that kinda like the BOV sound and have had them on a couple of turbo cars in the past, but if I’m riding my CanAm in muddy environments, should I consider a BRV instead since it’s a closed system?
I’m not submerging the car in mud or water, but many of the areas we ride in Tennessee are muddy. I’d hate to ingest water with a traditional BOV, but again, I like the sound of them.
The silicon charge tubes are virtually identical. The RPM BOV is a cheap sourced Chinese valve. The EVO valve is much higher quality. They bother work but if you hold the two side by side the RPM feels like junk.
Discussion starter · #26 ·
You can also buy just the Silicone kit from RPM and select your own high quality BOV or BRV or Dual port. Turbosmart and TIal make high quality parts. I got my Turbosmart dual port for about $150.
I have the EVO BOV and it's under muddy water/mud soup with some regularity and I've not had any issue. I do run the frogskin cover that came with it for added piece of mind.
If I was doing it again, I'd have bought EVO's recirculating one. The blow off is kinda neat when your on/off hard, but the constant soft woosh sound under light throttle gets annoying.
My understanding is that a BOV is not necessary in stock trim since there’s not enough back pressure. I’m new to this but that’s what I have read. Once you start adding more HP, the more important it becomes. Is that the case?
Discussion starter · #31 ·
On my 2020RR I have had the turbo stall (cha cha cha) with the car all stock. It all depends on how you drive the car.. I was always able to get it to do it when it is aggressively buildling boost and then chopping the throttle abruptly.
It's often called Turbo Flutter, Ausies call it Dosing. It is really obvious in the sand with 2 seat X3's because the turbo is right next to your head. I got tired of hearing the RPM brand BOV at slow speeds and swapped it to the Evo BRV. You can hear the BRV at high RPM's when you chop the throttle, it's right about when you'd hear the stock turbo flutter.
Also using the EVO BRV with EVO charge tubes and Dynojet intake tube (Evo was out of stock). No experience with the RPM, but the EVO setup is really well made and works great. Its also adjustable if necessary. It can be easily changed to blow off to atmosphere with the included plug and hose clamp. Takes about 5 minutes. So, the EVO is really 2 in 1.
This is a lot of good information. I'm just starting to put my plan together on building up my '19 X3, 120hp., XMR. Currently running a PV3 with AA tune and no intercooler. Want to use the yellow EVO boost tubes but they no longer offer them. Does anyone know where I could get the yellow boost tubes? Tried a few sites without any luck. Maybe some NOS items? Anyone else make yellow boost tubes? Is the intercooler w/fan from RPM a good choice? Looks like they offer some good packages.
21 - 40 of 67 Posts
