Any visible differences between the Maverick X3 R and the RR motor?
2.9K views 20 replies 6 participants last post by  jknapier
My spare motor is supposedly a rebuilt 2019 R motor. The number ID tag has been popped off it which is typical of motor rebuilders, it has the smaller R turbo but has the larger RR injectors. Both map sensors are off it also.
I have a depth gauge that I can put down in the spark plug hole and check for piston height, but is there a simpler way to determine which motor this is?
#3 ·
I was thinking that because the RR motor is a lower compression motor with the same piston diameter, that probably the piston wouldn't have the same travel as the R.
Any other ideas short of a tear down?
#6 ·
The stroke doesn't determine compression. The combustion chamber size and piston dome/shape usually do.
#7 ·
yeah you're exactly right That's what I was talking about. The head, the block, and the crank are identical to both RR and R motors, so that only leaves the pistons and the rods that make the difference . Short of all that, piston travel is the only difference
#8 ·
When you say "piston travel" you're referring to the stroke. This is not different on the two engines, they are the same displacement.
Reactions: HPnMORE4J
#12 ·
Yeah when I was talking about piston travel I wasn't talking about overall piston travel, I was talking about the height that it goes up into the top of the block. That is the things that would affect compression ratio. The RR does not use the same rods and pistons as the R. I'm taking bets on this
#13 ·
Only way for it to "go up into" the top higher is if the stroke is longer or the head is smaller. Easy to check on partzilla for the PN for the rods and pistons.
#16 ·
No such thing as a 2019 RR right? It looks like the first year of the RR is 2020.
Piston PN is the same (420893970) for a 2019 R and 2020 RR.
The rod is a different pn, rod bearing is the same.
