41 - 60 of 163 Posts
The impeller looks damaged from rubbing. I’m betting it is spinning on the shaft. Remove the shaft and impeller since it’s already junk. Clamp the shaft in a vise and try to turn the impeller. Either way you will need an impeller / shaft and a housing.
Remove the gears and check for broken or worn teeth. Replace as needed. This should solve your issue. When reinstalling, be sure to put the thermostat back.
So the whole housing needs to come off to do that? Oil cooler, ect...
Reactions: Bwedo1001
