1 - 1 of 1 Posts
Official Site Vendor
The XTR370 is a great tire that grabs everything in it's path.
Purchase online or start a conversation with Craig about this tire:
The System 3 Offroad XTR370 is a cross-terrain radial tire with advanced sidewall construction that provides a smooth, comfortable ride. Super-deep rim guard offers unmatched wheel protection and eliminates flats caused from pinching.
8-ply-rated radial carcass is proven durable.
Advanced sidewall construction delivers sure-footed and comfortable ride.
Deep tread ranges from 0.75 to 1.0 in. on 28-32 in. tires, and 1.0 to 1.25 on 33 in. and larger tires.
Multi-angle tread blocks at shoulder for improved side bite.
Super-deep rim guard protects your wheel investment.
SPECIFICATIONS
  • Tough, 8-ply carcass
  • 0.75" to 1.00" deep tread depth
  • Aggressive multi-angle shoulder tread
XTR370 X-TERRAIN RADIAL SPECIFICATIONS
SIZE - PLY RATING - DIAMETER - TREAD DEPTH - MAX PSI - MAX LOAD - WEIGHT - PART #
28 x 10R-14 - 8 ply rated - 28.1 in. - 0.75-1.0 in. - 18 psi - 1,002 lbs. - 37.2 lbs. - 522144
30 x 10R-14 - 8 ply rated - 30.1 in. - 0.75-1.0 in. - 18 psi - 1,134 lbs. - 41.4 lbs. - 522145
30 x 10R-15 - 8 ply rated - 30.1 in. - 0.75-1.0 in. - 18 psi - 1,113 lbs. - 41.9 lbs. - 522151
32 x 10R-14 - 8 ply rated - 32.1 in. - 0.75-1.0 in. - 18 psi - 1,293 lbs. - 45.9 lbs. - 522146
32 x 10R-15 - 8 ply rated - 32.1 in. - 0.75-1.0 in. - 18 psi - 1,260 lbs. - 45.6 lbs. - 522147
33 x 10R-15 - 8-ply rated - 33.1 in. - 1.0-1.25 in. - 18 psi - 1,350 lbs. - 53.6 lbs. - 522152
35 x 10R-15 - 8-ply rated - 35.1 in. - 1.0-1.25 in. - 18 psi - 1,452 lbs. - 59.1 lbs. - 522153
35 x 10R-20 - 8-ply rated - 35.1 in. - 1.0-1.25 in. - 18 psi - 1,353 lbs. - 55.1 lbs. - 522154
271034
1 - 1 of 1 Posts
