1 - 1 of 1 Posts
This kit is completely plug and play, no wires to cut, no crimping with only power and ground to hook up and plug into OEM harness. XTC’s kit uses the factory brake lights as turn indicators. Most other kits use one 3/4" marker light for each turn indicator. The factory lights are many times larger, making it much safer to be seen.
Since these vehicles are used primarily for off road use, XTC uses a lit switch on the dash, instead of those cumbersome turn levers that break off. It includes a lit Hazard Switch and rear power out for the license plate light or whip light.
[h=4]Kit Includes[/h]
  • 1 - Turn Signal Controller
  • 1 - Front Harness
  • 1 - Rear Harness
  • 1 - Carling Lit Turn Switch with Vertical Rocker
  • 1 - Horn
  • 1 - Switch Housing
  • 1 - 3/4" Lit Hazard Switch
  • 2 - 3/4" Front LED's
  • 2 - Self tapping screws
  • 15 - Cable Ties
  • 1 - Installation Instructions
[h=4]Mounts On[/h]
  • Can-Am Maverick X3 – All Years
XTC Turn Signal Kit @ SXSPerformance.com
1 - 1 of 1 Posts
