1 - 1 of 1 Posts
Plug N Play means no cutting of the factory harness, Just un-plug the connector from the tail light and plug our adapter in. It installs in minutes. You do not need to hunt around for those extra parts, everything is included, Plug & Play Adapter with 3' power wire, 2 heat shrinkable butt connectors, 3 cable ties. This adapter is for low current lights such as license plate or whip light, do not use on larger lights or it could cause the fuse to blow or damage the OEM wiring.
[h=4]Features[/h]
  • Easy Install Plug and Play
  • Wire Harness pre made with 3 wire connectors
  • 3' Power Cable
  • Includes Heat Shrinkable Butt Connectors and Cable Ties
  • Fits 2016 up Can-Am Maverick X3
XTC X3 Plug and Play @ SXSPerformance.com
1 - 1 of 1 Posts
