1 - 5 of 5 Posts
Just bought a used 2015 XRS DPS with really low miles & a bunch of accessories...I've only had it out for a few hours but the suspension is pretty stiff, so looking to soften it up if I can. I've been reading through every shock adjustment thread I can find (& i've got the manual to reference as well)...everything I see, including the manual, states the 2015 XRS has low & high speed compression & rebound adjust...but I do not see any rebound adjust on the shocks at all & I only see low a speed compression adjust. Is that perhaps a misprint for that model year or am I just crazy?
I don't see a way to turn the high speed compression CCW without literally un-screwing the whole thing (which at one point shock oil will come out). The manual says a 17mm but mine are a 16mm nut & it's one piece...not like two separate pieces in the manual.
I've had various ATV's & SxS's over the years but have never really tried tuning the shocks (as the ones I've had didn't have anything other than preload adjustments).
Any help would be appreciated.
Manual photo:
My shock:
Discussion Starter #5
That's weird. Take a pic of the bottom, and post. If you have high / low speed compression, you should have rebound.
I don't have high & low speed compression either...just one compression adjustment (the center one...the outer one just unscrews & will fall right out after leaking oil).
It's almost like I have the XRS with shocks from something else on them...but I'll post a pic of the bottoms of the shocks when I get home tonight.
1 - 5 of 5 Posts
