X3 wheel specs
123K views 105 replies 39 participants last post by  toddo
Has anyone out there been able to confirm wheel width and offset? Is the X3 using the same bolt pattern as the current Maverick.
#18 ·
Ok, so here is a summary of the wheel/tire specs, lug size, and lug nut specs.
12mm lugs with a 1.5 thread pitch
M12x1.5 lug nuts
Wheel/tire specs for X3 base:
Non-beadlocks and non-square setup
Front 14x7 with 55mm of offset which is 6.17" of backspacing with a 28x9x14 bighorn
Rear 14x8 with 76mm of offset which is 7.5" of backspacing with a 28x11x14 bighorn
Wheel/tire specs for X3 XDS:
Beadlocks but non-square setup
Front 14x7 with 55mm of offset which is 6.17" of backspacing with a 29x9x14 bighorn
Rear 14x8 with 76mm of offset which is 7.5" of backspacing with a 29x11x14 bighorn
Wheel/tire specs for X3 XRS:
Beadlocks and Square setup
Front and Rear 14x7 with 55mm of offset which is 6.17" of backspacing with a 30x10x14 bighorn
#46 ·
It appeared the front and rear wheels were tucked in fully, so going wider won't be an issue but you won't be able to narrow it any. I have a feeling they used the wheels to keep them as narrow as possible while making the arms as wide as possible.
Socalmav confirmed the larger studs.
#56 ·
15 XDS is 10 mm.
I bet the wheels could be drilled, but the aftermarket wheels may already accept 12 mm studs as they are more common than 10mm. Tim
#59 ·
Anyone able to get the weight on the stock X3 wheels yet, or at least a guess? If we get the XRS, I might just do like "Maverick4me" and get (4) stock wheels and slap some Skats on it. I'd really like to stay as close to 72-ish" wide as possible. I called around to a couple tire/wheel vendors today and it seems no one has after market "factory offset" wheels.
The stock wheels are tucked in pretty good...so on the 14x7, it's probably like what 1+6 offset???
#61 · (Edited)
Feisty bunch!
Glad to find this thread. I'm studding my Bighorns for the winter and am looking for an all-round "rest of the year tire" tire.
Tusk Terrabite, Maxxis Liberty and Tensor regulator in 30x10x14 have made the short list. (All DOT)
See http://www.maverickforums.net/forum/15-wheels-tires/42610-good-all-around-30x10x14-tire-3.html
Now the wheels with 4" overall width increase on XDS (64")...
-Is a square set up the way to go?
-What size wheel?
-Why 8 and not 9 if your replacing all four? (do they make 9"?)
-How critical is the need for beadlocks?
