The UTV INC Can Am Maverick X3 Max Opening Doors are a stock replacement 4 door system.
Constructed out of steel and TIG welded for strength.
CNC laser cut door skins adorn the frames and provide total side coverage from the elements you encounter out on the trail.
The door skins have strengthening break bends into them to provide structure and rigidity to them.
This helps with vibrations and adds a stylish look vs a plain flat skin.
We also roll the skin over the door frame at the top so there is not a sharp, flat edge just sitting on the tube.
The door frames and skins are powder coated satin black to provide a durable, lifelong finish.
UTV INC supplies new hinges to allow adjustment of the doors to match your X3 Max body line.
You do reuse the stock door latches and limiting straps.
All 4 doors can open and close independent of one another at any time.
This means the rear passengers can get in out of the car regardless of what the front doors are doing.
This door kit works with the UTV INC door handle kit, front & rear, but handles are sold separately.
These doors provide function and style to your side by side!
$1,550.00
Available here: https://www.utvinc.com/utv-inc-can-am-maverick-x3-max-full-opening-doors/
$1,550.00
