1 - 11 of 11 Posts
Has anybody else not been able to get the spindle off of the axle? Was trying to grease the bearings. I’ve tried everything I can think of I’ve got it out 1 inch but I can’t get it to release I think the CV joint hub was over torqued into the spindle housing. Any suggestions on how to free this up to get it off will be appreciated. FF35AF4D-9306-4A9F-9AC6-35673B7BC52F.jpeg 0B308CA1-7788-451A-B7A0-B154222656B5.jpeg 0B308CA1-7788-451A-B7A0-B154222656B5.jpeg
I’ve tried every penetrating spray. I watched Kroil work on items nothing else would. Amazing stuff.
Use a heat gun or propane torch on the wheel adapter
Discussion Starter #5
Thanks I used liquid wrench and a propane torch got it off the spindle ? then I feel like an idiot because the hangup was the disc guard that no videos show D677283D-639C-40EF-A662-28CD07B2E973.jpeg that it needs to be unbolted from the bottom of the swingarm carriage with 4 ea 10 mm bolts
Yes get rid of that part.
Thanks I used liquid wrench and a propane torch got it off the spindle ? then I feel like an idiot because the hangup was the disc guard that no videos show View attachment 250629 that it needs to be unbolted from the bottom of the swingarm carriage with 4 ea 10 mm bolts
Was gonna say remove the rock scrapers ..seen this come up so many times .i banged my head over this also.. hod you got it sorted.
Well we’re glad you figured it out.
It is well documented on this forum that that’s the first part you take off your rig when you bring it home.
I recommend you spend about 10 hours reading the early classic posts it will explain another 20 things you need to be aware of and do right away in order to enjoy hours of trouble free riding.
1 - 11 of 11 Posts
