1 - 1 of 1 Posts
I'm having an issue with the stock 3 post power dist. block under the center console passenger side. The center is battery power, bottom post should be key power... thought it was working then switched 2 wires so radio can run constant. now I have no key on power on the bottom post, checked fuse in the top fuse box (green 30) and it is good. Thanks, just trying to fix a few hings a local shop did to my rig when they installed radio.
1 - 1 of 1 Posts
