1 - 5 of 5 Posts
ATTENTION X3 owners! We have seen some BRP primary clutch thrust rollers wear excessively and break in half causing poor shifting and clutch damage, this is applicable to all X3 clutches stock or modified, the thrust rollers are a wearable item and need to be maintained. This particular set failed at [email protected] The roller inspection is recommended every 2000miles/100hours or 1000miles/50hours in extreme conditions along with the complete disassembly and inspection of the clutches. KWI Clutching recommends all X3 owners inspect these for wear and rotate them every 500 miles regardless of riding conditions. Instructions for inspection, rotation and replacement will be posted on www.kwiclutching.com later today.
Discussion Starter #3
Yes to replace, no to inspect and rotate. You will need to have the governor cup pulled by your dealer or a qualified clutching professional to replace these. To inspect and rotate these you can do it with the clutch assembled and on the machine with some care.
1 - 5 of 5 Posts
