Some interesting improvements for the clutching
usually the p drive uses a special notched crank
so to retrofit you will need a notched crank
This is based on all previous pdrive applications
and I have not seen the pdrive used by canam...yet
Thats exactly what a can am rep said at show. Only can be use 2220 and 2021Can Am says the P Drive can be retrofit on a 2021+ model.
2020 and earlier is a no go. Not sure what the difference is between a 2020 and 2021.
Not sure about the 2220 model year.Thats exactly what a can am rep said at show. Only can be use 2220 and 2021
Manufacturers know what they're doing 5 years down the road, if not more. So they knew in 21 they were going to change in 22, so make the 21s able to retrofit.This is some damn bullshit haha. Interesting it fits on the 2021 and not the older ones.
Yeah haha. I would guess this means that they probably aren’t keyed though as I don’t think the 21’s are, but maybe so I haven’t personally taken one apart. I haven’t heard they are though either.Manufacturers know what they're doing 5 years down the road, if not more. So they knew in 21 they were going to change in 22, so make the 21s able to retrofit.
Yeah i heard that as well. Someone will have to cross reference all the part # between the 2020 and 2021 ...hahaCan Am says the P Drive can be retrofit on a 2021+ model.
Too bad RMATV doesn’t have their 2021 parts diagrams up yet.Yeah i heard that as well. Someone will have to cross reference all the part # between the 2020 and 2021 ...haha
I was just going to say that haha. I will go see what I can see...Yeah i heard that as well. Someone will have to cross reference all the part # between the 2020 and 2021 ...haha
