421 - 440 of 841 Posts
2020 XRC Turbo RR
Ya I was bummed out when I saw my build date was 1/21, and tune is still not available. Only good thing is the Portals with the 30% gear reduction will make lots of torque, and make the 37 inch tires seem like 28 inch tires.
How much do 37" SXS tires weigh? My 37" Toyo RT's on KMC wheels weighed 95lbs. My 40's on Trail Ready's weigh 150lb each.
Discussion Starter · #424 ·
My 37X10.5 MRT X ROX CRAWLER TIRES R18 Kevlar MRT/XROS DD STICKY with the 18X7 MSA M37 Brute Beadlock 4/137 (Combo 80LBS)
Discussion Starter · #425 ·
I bought this lift for the Can Am before I added all the extra weight to it. I added a 12 inch lift to it so it will at least have enough lift height to get the wheels off the ground. I am definitely going well beyond the rated lift capacity, so I will have to add some extra steel reinforcement to a few areas, and possible upgrade the jack to a 20 Ton. Once I have a chance to test it to see what is needed I will have the wood changed to steel to help in the over all strength. The wood lift extension is just temporary to find my ideal height so, I didn't take the time to make it perfect.
My 2 seater with an aftermarket cage, me in it (150lb), 32" tires and lightweight wheels was already at 2100lbs. I've done some weight reduction since. But yours being a 4 seater with all of this heavy stuff on it, wheels, tires, gas tank, portals, stereo, etc. I would bet money its over 3000lbs wet with you in it. Curious to see.
Discussion Starter · #430 ·
I am guessing I can get the most accurate weights of all four corners when I have the Can Am at Shock Therapy June 28th. I will weigh front and back at a local sale, so I will have a rough idea of weight.
Car looks good. You will have it all built just in time to hit the desert when it is 110 degrees. LOL!
Discussion Starter · #433 ·
Modified my trailer to 86 inches between fenders. Now I will be able to load it to find correct balance points to weld in the d-rings for the Wheel straps. Since my Can Am won't fit thru the dealers showroom front doors I will have to wait until they move it back into the service area to get it loaded for correct balance points to finish putting on D-Rings, and a few other trailer modifications I am doing.
Discussion Starter · #434 ·
Ross Hydro Steer has been shipped and scheduled to arrive this Friday. I should have some more Install pictures by end of next week. :)
Discussion Starter · #437 · (Edited)
Getting Closer. All parts have Arrived. Dealer should start working on the build by end of this week. Today I loaded it up to see how it fits on my trailer, and marked all 8 points for D-Rings to weld in.
Discussion Starter · #439 ·
One good thing about it, you don’t have to worry about getting it loaded off center on the trailer. I swear I miss it every dang time I load up, get out look at it and back it off to move one side or the other. Lol
That is true. If I am off 3/4 inch I hit the fenders.
