Ok ,I don't think I fkd this up,I think wrong parts are sent.
Installed rack,no probs,made an extra plate out of 3mm plate for in behind factory mounting plate, might make it abit more rigid there ?
Installed p/s unit no probs,
Installed short shaft between unit and column,
Lightly bolted unit up to factory location piont,
Bolted mounting plate for shaft heim to brake m/c.
Used supplied long shaft with heim on it ,pushed on rack and through firewall,
Then, hmmmm
P/s unit splined, and so is long shaft to allow the heim to slide on,
Need another uni,but none supplied.
They only supplied another short shaft to go to the factory column with no p/s.
The other long shaft supplied will link between the p/s unit and rack but unis are welded so heim can't be installed.
Do I need to run the heim support?
Should I cut and shut the shaft and install heim?
Or should I wait 100 years for a response from seller and another 100 for them to post?
Grrrr ova this shit,
Unit was ordered together stating p/s to suit rackzilla.
Then, hmmmm
