No, you do not understand. The outer race is solid, the inner race is split. The grease groove on the tool lines up with the gap in the inner race.so if i understand correctly your greasing the outer ring which doesn't do anything for the bearing?? I know on older 4x4's where the bearing wasn't sealed this would work but if the bearing is sealed your really not doing anything but putting grease where it is not needed?
Not trying to be a smartass or anything, but did you remove the brake caliper?On this topic, does anyone have some advice for getting the rear hubs off? I attempted one side last weekend and even after hitting the axel in with a dead blow hammer (what a guy did on a youtube video), I couldn't get the hub to come out. I was worried if I really got after it with pry bar etc., I'd bend/break something. Thoughts? Thanks.
So the sealed bearing really isn't sealed??SxS bearings are actually 2 bearings back to back in a single housing. The grease is injected into the seam and will come out the outer seals. The grease tool push's out old grease, dirt and water and replaces the old grease with new.
thanks for the explanation--Technically speaking it is semi sealed. There are seals on the outside and then when you install the hub the inner race of the bearing is up against the spindle flange and the nut on the front side of the hub. Does it stop the water and dirt from entering the bearing, no. Before these bearing tools were available I would seal the inner race with silicone to help keep the water and mud out. Its not a fix all because water and dirt also penetrates the outer seals. Hope that helps.
Ok, fair question I guess but yes, brake caliper off and out of the way, and yes, I removed the cotter pin and the axle nut as well. I even started by jacking the car up and taking off the tire/wheel first! But, seriously, that's why I was a little curious as to why the hub wasn't coming out with quite a bit of force. How much is usually required? I didn't check the bearings until now at 1600 miles so I'm a little worried that the recess is galled to the bearing. Anyone else find the rear hub hard to get out?Not trying to be a smartass or anything, but did you remove the brake caliper?
Also the OD of the spline snout may be rusted and not sliding out of the bearing inner race.The hub may be rusted on the axle stub splines.
The hub may be rusted on the axle stub splines. Try soaking it with PB Blaster over night. I would try a 3 jaw puller to get the hub off. That way your not beating on it with a slide hammer. I would also put a little never seize on the splines when you put it back together. Use never seize sparingly as it tends to migrate onto other parts.
The axle will move and I hit it with a plastic mallet to get it moving inside of the hub. I'll go puller route next. I'm worried about that inner bearing race. Thanks for the suggestions.Also the OD of the spline snout may be rusted and not sliding out of the bearing inner race.
You should be, but it's not the race it's the hub snout.I'm worried about that inner bearing race.
