I run 93. The sticker by the filler says 91 or super 95 but I dunno what that is. I wonder if a slight shot of octane boost every fillup would help. Who knows.
its Canada fuel rating RON 95 is 91 us
Wickapedia:
Measurement methods
The most common type of octane rating worldwide is the Research Octane Number (RON). RON is determined by running the fuel in a test engine with a variable compression ratio under controlled conditions, and comparing the results with those for mixtures of iso-octane and n-heptane.
There is another type of octane rating, called Motor Octane Number (MON) or the aviation lean octane rating, which is a better measure of how the fuel behaves when under load. MON testing uses a similar test engine to that used in RON testing, but with a preheated fuel mixture, a higher engine speed, and variable ignition timing to further stress the fuel's knock resistance. Depending on the composition of the fuel, the MON of a modern gasoline will be about 8 to 10 points lower than the RON. Normally fuel specifications require both a minimum RON and a minimum MON.
In most countries (including all of Europe and Australia) the "headline" octane rating, shown on the pump, is the RON, but in the United States, Canada and some other countries the headline number is the average of the RON and the MON, sometimes called the Anti-Knock Index (AKI), Road Octane Number (RdON), Pump Octane Number (PON), or (R+M)/2. Because of the 8 to 10 point difference noted above, the octane shown in the United States is 4 to 5 points lower than the same fuel elsewhere: 87 octane fuel, the "regular" gasoline in the US and Canada, is 91-92 in Europe. However most European pumps deliver 95 (RON) as "regular", equivalent to 90-91 US (R+M)/2, and some even deliver 98 (RON) or 100 (RON).
It is possible for a fuel to have a RON greater than 100, because iso-octane is not the most knock-resistant substance available. Racing fuels, AvGas, LPG, and alcohol fuels such as methanol or ethanol can have octane ratings of 110 or significantly higher - ethanol's RON is 129 (MON 102, AKI 116). Typical "octane booster" gasoline additives include tetra-ethyl lead, MTBE and toluene. Tetra-ethyl lead (the additive used in leaded gasoline) is easily decomposed to its component radicals, which react with the radicals from the fuel and oxygen that start the combustion, thereby delaying ignition, leading to an increased octane number.
