Can-Am X3 Front Suspension Limit Strap System
The ultimate suspension and drive train problem solver for your X3!
Protect your axles & suspension components by preventing over extension and causing catastrophic failure.
We have a unique and simple design that utilizes our shock tower brace as a mounting point for the limit straps. No more need for complex mounting, with our system you get two solutions from one single kit!
Our limit straps are manufactured using the same high strength webbing material used for seat belt material in all OEM manufacturing. We then raise the bar even more by providing a double layer of sewn material. Our strap webbing is designed to have a load strength of twelve thousand pounds! You can rest assured our system will do its job time and time again.
Hassle-Free Lifetime Warranty included!
Be sure to view our quick detach sway bar links to have the perfect suspension system!
NOTE: 64" HCR BRAND UPPER CONTROL ARMS REQUIRE A DIFFERENT SET UP. IF YOU ARE RUNNING HCR BRAND UPPER CONTROL ARMS, CALL US 423-790-0230 TO PLACE AN ORDER FOR THE CORRECT SET UP.
Features:
Includes:
Features:
- 6061 billet aluminum
- Superior straps made from dual layer material rated at 12,000 lbs breaking strength to ensure your machine is well protected
- Grade 10.9 hardware
- Stainless Spacers
- Proudly made in the U.S.A
Includes:
- Billet aluminum shock tower brace
- Frame gusset plate
- Pair of limit straps
- Rubber grommet
- All necessary hardware
