Make sure all surfaces are clean and do a star pattern on torqueing the bolts. get them all started first then bring them all to even pressure we usually use a electric drill motor and set the clutch low then bring it up as needed for a perfect seetI just removed my MSA Vice 16 Bead Lock Rings to have them powder coated Manta Green. What do I need to do to ensure that my EFX 10x30x14 Motoclaw's bead seals back up well again? Do you use dish soap or just get them very clean? What are the torque spec's and tightening sequence on outer rings? Does anyone have this info for MSA Vice 16 Bead Lock Rings (I couldn't find it on their web site).
I did blow all the dust/dirt out of the bolt holes already. And because I didn't break the inner bead loose, I shouldn't have to worry about a balance or out-of-round issues.....correct?
Any info or help is greatly appreciated.
