1 - 2 of 2 Posts
Hey all I have a water seal problem. Temps are in F. I had new water seal put on the motor when bought it. Had no leaks for 700 miles till last month with temp went to 40s, it was a slow leak then stopped. No problems till the next week to ride with temps around 30s then it was a steady stream flowing out. Replaced the water seal, no leaks till 30s outside steady stream again. I assumed I broke the seal installing it. Went to move machine in 60s to replace it, no stream. What is going on? Is seal needing replaced or cold weather makes it leak?
Replace the seal. They don't leak in the cold because its cold. Lots of Canadians on here with zero leaks. I've had quite a few below freezing rides
1 - 2 of 2 Posts
