1 - 5 of 5 Posts
FREE SHIPPING!
Valvetronic exhaust system allows at the flip of a switch to open and close a valve to re route the exhaust flow path. Allowing you to adjust sound level and performance.
With the exhaust valve open, you can now hear the turbo spool up as you accelerate through the RPMs. The incredible new sound can be heard from far making you stand out amongst your others. When cruising the roads or trails and you need it quiet, simply close the valve to have a near stock sound that is very subtle. Tuning is not required when doing this exhaust or when adding a cat delete pipe. Improvements in horsepower and throttle response or instantly noticed!
  • Full Stainless Steel Construction
  • Industry First Valvetronic Design
  • Quiet and Race Modes
  • Integrated Exhaust Tips
  • Modular Design
  • Does Not Require Tuning
Valvetronic Exhaust System Can-Am Maverick X3
Discussion Starter #2
To operate the valvetronic exhaust, a custom made plug and play switch by XTC Powersports is included. This switch features color matching LEDs for the on and off position. It is designed to be mounted on the center dash or the center console. If you mount it up on the center dash by the start and stop button, the switch plugs into an existing port already available. If you mount it on the center console, the CANBUS bar is located under this trim to easily tie in the power and ground. The valve operates using vacuum pressure. Each kit includes a vacuum block that is fitted to the stock intake manifold. Here you connect the solenoid that is operated by the switch to open and close the valve.
1 - 5 of 5 Posts
