1 - 15 of 15 Posts
Anyone know what the valves are supposed to be set at. I have all my plastic out after getting my starter recall so I thought I would check my valves.
Valve clearance
Intake 0.06 mm to 0.14 mm (.0024 in to .0055 in)
Exhaust 0.11 mm to 0.19 mm (.0043 in to .0075 in)
That seems like a large spread to me!
Straight out of the manual….
Banned
set them on the tight side. THe high end is aloable for wear.. The more lash the less lift =)
If Im on the side of the trail posting ... its because Im waiting for you to catch up.
Discussion Starter · #9 ·
Valve clearance
Thanks, I've got a manual for a commander but I figured the specs would be different and the procedure would be the same.
no problem….I had it open so it didn't take me long to find it….
Discussion Starter · #11 ·
I just checked these specs with my commander manual and they are the same. Now I can put off buying a maverick manual until I need to know something else.
I PM'ed you...
1 - 15 of 15 Posts
