1 - 20 of 101 Posts
Official Site Vendor
LINK: https://www.utvinc.com/utv-inc-can-am-maverick-x3-v1-0-roll-cage/.html
UTV INC CAN AM MAVERICK X3 V1.0 ROLL CAGE
UTV INC's cage for the Can Am Maverick X3 features a small radius design while lowering the rear of the cage down approx 1" over stock. The V1.0 is manufactured in house out of .095x 1.75" DOM steel and is TIG welded to precision. The price shown will include the aluminum roof which attaches to the cage via dzus fasteners. A rear view mirror bung and 1 heavy duty center whip mount comes standard. Price does not include powder coating of the cage or roof. YOU MUST CUT OFF YOUR STOCK ROLL CAGE TO INSTALL THIS ITEM. UTV INC highly recommends having a professional offroad or automotive customizing shop install this item if you are not local to us. We have a handful of options below to customize the base cage to your desired needs & wants.
UTVs, SxS's, ROV's can be hazardous to operate! Off-roading can result in serious injury or death. For your safety please ensure you and your passenger(s) have adequate headroom when installing this AFTER MARKET cage onto your machine. ALWAYS wear proper safety gear! This cage is not designed as an added safety feature to your vehicle. The aluminum roof is designed for sun shade only, and will not stop objects from protruding into the occupant area. You should only operate your vehicle after taking an off-road safety course.
$1,650 + options
*FRONT LIGHT BAR TABS:
*FRONT V BRACING:
*TWO WAY RADIO ANTENNA MOUNT IN ROOF:
*WHIP TABS:
*POWDER COAT CAGE & ROOF: (ENTER COLOR BELOW):
Discussion Starter #6
Check out our new UTV Inc. X-3 cage. It's made from 0.95 DOM steel, all TIG welded and comes with an aluminum roof.
Discussion Starter #9
Need to change up your new X-3? Check out our UTV Inc. Maverick X-3 cage with roof.
Discussion Starter #11
Need to cage your new beast? UTV Inc. has you covered with our X-3 V1 roll cage with roof.
1 - 20 of 101 Posts
