61 - 80 of 155 Posts
Official Site Vendor
Discussion Starter · #61 · (Edited)
Is your Can Am Maverick X3 bed melting all the ice in your cooler and giving you 3rd degree burns? Well help defeat the heat with the UTV INC UNDER BED HEAT SHIELD for the Can Am Maverick X3 models! Includes hardware to attach to the underside of the bed. Heat shield will attach all OEM locations for mounting. Simply remove the bed, flip it over, install the heat shield and install the bed back on the machine. Quick and easy! We have noticed an incredible amount of heat deflection and the bed temps have been significantly cooler to the touch with this installed.
$70.00
LINK:https://www.utvinc.com/utv-inc-can-am-maverick-x3-under-bed-heat-shield/
Discussion Starter · #68 ·
Is your Can Am Maverick X3 bed melting all the ice in your cooler and giving you 3rd degree burns? Well help defeat the heat with the UTV INC UNDER BED HEAT SHIELD for the Can Am Maverick X3 models! Includes hardware to attach to the underside of the bed. Heat shield will attach all OEM locations for mounting. Simply remove the bed, flip it over, install the heat shield and install the bed back on the machine. Quick and easy! We have noticed an incredible amount of heat deflection and the bed temps have been significantly cooler to the touch with this installed. Click on the link below for more info.
Discussion Starter · #72 · (Edited)
$70.00
Discussion Starter · #78 ·
This item is currently not on sale, however you can use promo code THANKYOU at the cart screen to save some $$$!
