101 - 120 of 147 Posts
· Official Site Vendor
Discussion Starter · #102 ·
Wanting to replace the OEM pull strap with an easy to use door handle on your Can Am Maverick X3 models? Well here you go! Sold as a pair. OEM replacement kit, easy installation. Makes the opening of the door feel more ergonomically correct with a pull up handle design. CNC laser cut from 1/8" steel, then they are deburred by hand, tumbled smooth, hand sanded to ensure the smoothest of edges, and powder coated black to ensure safe operation as well as a durable finish!
Note: Will work with plastic cover, but requires trimming. Will work on 2018 or newer models, but you will have to drill a hole in your latching mechanism to bolt them on.
*Works on FACTORY doors and UTV INC doors.
*X3 MAX will require two sets
LINK: https://www.utvinc.com/utv-inc-can-am-maverick-x3-black-door-handle-kit/
Discussion Starter · #105 ·
Discussion Starter · #107 ·
Discussion Starter · #113 ·
Wanting to replace the OEM pull strap with an easy to use door handle on your Can Am Maverick X3 models? Well here you go! Sold as a pair. OEM replacement kit, easy installation. Makes the opening of the door feel more ergonomically correct with a pull up handle design. CNC laser cut from 1/8" steel, then they are deburred by hand, tumbled smooth, hand sanded to ensure the smoothest of edges, and powder coated black to ensure safe operation as well as a durable finish! Will work with stock plastic cover, but requires trimming. Works on FACTORY doors and UTV INC doors. Can An Maverick X3 Max will require two sets.
LINK: https://www.utvinc.com/utv-inc-can-am-maverick-x3-black-door-handle-kit/.html
Discussion Starter · #117 ·
LINK: http://www.utvinc.com/utv-inc-can-am-maverick-x3-black-door-handle-kit/.html
Discussion Starter · #119 ·
