1 - 20 of 147 Posts
· Official Site Vendor
LINK: https://www.utvinc.com/utv-inc-can-am-maverick-x3-black-door-handle-kit/
Special Price $38.00
Wanting to replace the OEM pull strap with an easy to use door handle on your Can Am Maverick X3 models? Well here you go! Sold as a pair. OEM replacement kit, easy installation. Makes the opening of the door feel more ergonomically correct with a pull up handle design. CNC laser cut from 1/8" steel, then they are deburred by hand, tumbled smooth, hand sanded to ensure the smoothest of edges, and powder coated black to ensure safe operation as well as a durable finish! This product can ship USPS for under $4 to the lower 48 states.
Note: Will work with plastic cover, but requires trimming. Will work on 2018 or newer models, but you will have to drill a hole in your latching mechanism to bolt them on.
*Works on FACTORY doors and UTV INC doors.
*X3 MAX will require two sets
Discussion Starter · #5 · (Edited)
$38.00
Wanting to replace the OEM pull strap with an easy to use door handle on your Can Am Maverick X3 models? Well here you go! Sold as a pair. OEM replacement kit, easy installation. Makes the opening of the door feel more ergonomically correct with a pull up handle design. Laser cut & powder coated black.
Installed with our doors:
Discussion Starter · #6 ·
Wanting to replace the OEM pull strap with an easy to use door handle on your Can Am Maverick X3 models? Well here you go! Sold as a pair. OEM replacement kit, easy installation. Makes the opening of the door feel more ergonomically correct with a pull up handle design. Laser cut & powder coated black. Click on the link below for more info.
LINK:https://www.utvinc.com/utv-inc-can-am-maverick-x3-black-door-handle-kit/
Discussion Starter · #9 ·
*THESE WILL FIT THE X3 MAX REAR DOORS ALSO
Discussion Starter · #11 ·
Discussion Starter · #12 ·
Discussion Starter · #15 · (Edited)
Wanting to replace the OEM pull strap with an easy to use door handle on your Can Am Maverick X3 models? Well here you go! Sold as a pair. OEM replacement kit, easy installation. Makes the opening of the door feel more ergonomically correct with a pull up handle design. Laser cut & powder coated black. Works with the stock doors or our UTV Inc. X3 door kit. Click on the links below for more info.
$42.00
Discussion Starter · #17 ·
Discussion Starter · #19 ·
1 - 20 of 147 Posts
