UTV INC Can Am Maverick X3 odyssey PC925 battery hold down strap
26397 Views 113 Replies 3 Participants Last post by  UTV Inc
4
Want to install an Odyssey PC925LMJ into your stock Can Am Maverick X3 battery tray? Our sturdy metal UTV INC battery strap will hold the PC925LMJ in the stock location with out any modifications. Works with the UTV INC Battery & ECU covers as well!
*Not compatible with PC1200 battery
*For use with Odyssey PC925LMJ battery
$39.00
LINK:
https://www.utvinc.com/utv-inc-can-am-maverick-x3-odyssey-pc925-battery-hold-down-strap/
(UTV INC X3 battery cover sold seperately)
LINK: https://www.utvinc.com/utv-inc-can-am-maverick-x3-battery-cover-plate/
See less See more
61 - 80 of 114 Posts
Want to install an Odyssey PC925LMJ into your stock Can Am Maverick X3 battery tray? Our sturdy metal UTV INC battery strap will hold the PC925LMJ in the stock location with out any modifications. Works with the UTV INC Battery & ECU covers as well! *Not compatible with PC1200 battery.
LINK: UTV INC CAN AM MAVERICK X3 ODYSSEY PC925 BATTERY HOLD DOWN STRAP
See less See more
Check out our UTV INC X3 Odyssey PC925LMJ battery hold down strap. Click on the link below for more info.
See less See more
In stock and ready to ship.
Want to run a PC 925 LMJ in your X3? We have the solution with our UTV INC PC 925 battery strap.
See less See more
Check out our UTV INC X3 PC 925LMJ battery strap. This will hold the Odyssey PC 925 L- left hand terminal, MJ- metal jacket in the factory location. The battery will need to be the PC 925LMJ to fit correctly. And you can use our UTV INC X3 battery cover with this set up.
See less See more
*REQUIRES ODYSSEY PC 925LMJ BATTERY
See less See more
2
See less See more
See less See more
In stock andready to ship.
Now you can install the Odyssey PC925LMJ battery in the stock location with our UTV INC PC925 battery srtap.
2
See less See more
Want to mount your Odyssey PC925LMJ battery in your X3? UTV INC has you covered with our X3 Odyssey PC925LMJ battery strap. It will allow you to mount the PC925LMJ battery in the stock location and you can use the UTV INC X3 battery cover sold seperately.
