81 - 100 of 103 Posts
Official Site Vendor
Discussion Starter · #84 · (Edited)
Easily charge, or jump start your Can Am Maverick X3 SXS model with the UTV INC CAN AM MAVERICK X3 ADDITIONAL BATTERY JUMP POST TERMINAL & CHARGER KIT. Additional power and negative battery terminals allow you to charge quickly, and easily, or jump start your machine. Kit also includes Battery Tender port to easily keep your battery charged. Terminals will be relocated to the back of the machine, inside passenger side fender well for easy access. Mounting bracket is CNC laser cut from aluminum and comes powder coated black. We provide stainless steel mounting hardware to attach to your machine. NO MODIFICATION REQUIRED FOR INSTALL. Abrasion resistant loom on power and ground cables. Terminal are connected to OEM battery using copper terminal.
LINK: UTV INC CAN AM MAVERICK X3 ADDITIONAL BATTERY JUMP POST TERMINAL & CHARGER KIT
Discussion Starter · #86 ·
Easily charge, or jump start your Can Am Maverick X3 SXS model with the UTV INC CAN AM MAVERICK X3 ADDITIONAL BATTERY JUMP POST TERMINAL & CHARGER KIT. Additional power and negative battery terminals allow you to charge quickly, and easily, or jump start your machine. Kit also includes Battery Tender port to easily keep your battery charged. Terminals will be relocated to the back of the machine, inside passenger side fender well for easy access. Mounting bracket is CNC laser cut from aluminum and comes powder coated black. We provide stainless steel mounting hardware to attach to your machine. NO MODIFICATION REQUIRED FOR INSTALL. Abrasion resistant loom on power and ground cables. Terminal are connected to OEM battery using copper terminals.
Discussion Starter · #89 ·
Discussion Starter · #97 ·
We also offer.
NOCO® Genius1 Battery Charger
Similar to the G750, the Genius1 is a 1-Amp Battery Charger that's 35% smaller and delivers more power than its predecessor. Designed to charge, maintain or restore 6- and 12-Volt lead-acid batteries, including flooded, AGM, gel, maintenance-free and lithium-ion. Plug-in, connect the battery, select a mode and go.
LINK: NOCO® Genius1 Battery Charger
Discussion Starter · #99 ·
