1 - 20 of 102 Posts
Official Site Vendor
Easily charge, or jump start your Can Am Maverick X3 SXS model with the UTV INC CAN AM MAVERICK X3 ADDITIONAL BATTERY JUMP POST TERMINAL & CHARGER KIT. Additional power and negative battery terminals allow you to charge quickly, and easily, or jump start your machine. Kit also includes Battery Tender port to easily keep your battery charged. Terminals will be relocated to the back of the machine, inside passenger side fender well for easy access. Mounting bracket is CNC laser cut from aluminum and comes powder coated black. We provide stainless steel mounting hardware to attach to your machine. NO MODIFICATION REQUIRED FOR INSTALL. Abrasion resistant loom on power and ground cables. Terminal are connected to OEM battery using copper terminals
$110.00
LINK: UTV INC CAN AM MAVERICK X3 ADDITIONAL BATTERY JUMP POST TERMINAL & CHARGER KIT
Fits ALL Can Am Maverick X3 Models (including Max) – NO MODIFICATION REQUIRED
Adds Additional Positive (+) and Negative (-) Battery Terminals To Your Can Am Maverick X3
Includes Battery Tender Charing Port As Well – Easily Charge Your Battery!
Additional Battery Terminals Are Great For Charging And Jump Starting
5052 Aluminum Mounting Bracket (Powder Coated Black), Abrasion Resistant Loom, Copper Terminal Ends, & Stainless Steel Mounting Hardware Included
Discussion Starter · #8 ·
Discussion Starter · #12 ·
Easily charge, or jump start your Can Am Maverick X3 SXS model with the UTV INC CAN AM MAVERICK X3 ADDITIONAL BATTERY JUMP POST TERMINAL & CHARGER KIT. Additional power and negative battery terminals allow you to charge quickly, and easily, or jump start your machine. Kit also includes Battery Tender port to easily keep your battery charged. Terminals will be relocated to the back of the machine, inside passenger side fender well for easy access. Mounting bracket is CNC laser cut from aluminum and comes powder coated black. We provide stainless steel mounting hardware to attach to your machine. NO MODIFICATION REQUIRED FOR INSTALL. Abrasion resistant loom on power and ground cables. Terminal are connected to OEM battery using copper terminals.
270868
This is a great idea.
Every X3 should have this.
The battery is such a pain to access.
Reactions: Hollywood X3
Discussion Starter · #16 ·
271174
1 - 20 of 102 Posts
