1 - 4 of 4 Posts
Official Site Vendor
When dropping your aftermarket seats to the lowest setting in your Can Am Maverick X3 you will run into some clearance issues. The UTV INC 8pc Billet Aluminum Seat Base Spacer Kit will give you just the correct amount of clearance so you do not have to modify your Can Am Maverick X3, and put the seat in the lowest front and rear position. Mounts between the seat and the adjustment slider frame to space the seat up, just the right amount to clear the front mounting holes. Allows Aftermarket Seats To Be Mounted In Lowest Position CNC Machined From 6061 Billet Aluminum 8 Piece Spacer Kit – Good For 2 Seats Works With Most Aftermarket Seats No Modification To Your Machine, 100% BOLT ON.
LINK: UTV INC CAN AM MAVERICK X3 8 PIECE BILLET SEAT BASE SPACER KIT
Discussion Starter #4
LINK: https://www.utvinc.com/utv-inc-can-am-maverick-x3-8-piece-billet-seat-base-spacer-kit/.html
1 - 4 of 4 Posts
