21 - 40 of 183 Posts
Quite a project you got going there Mega. Have fun and good luck with it. As far as the wiring goes, why not just buy a Max harness and be done with it. That way your not dealing with splices and margin of error.
I was thinking the same thing.
I am not too far from Mega, I could loan him a crow bar and some WD40 to pry open his wallet....!
:D
Discussion Starter #22
error? I made a mistake once, but then i was wrong and turned out is was just a fart. I figure why not, what’s the worst that can happen.
There is an old saying there buddy, "What can go wrong will go wrong" lol One wire terminated with the wrong wire could at the least cause you hours of troubleshooting. Down the road when corrosion builds up (and it will sooner or later) in one or more of your splices causing intermittent running issues that you may or may not ever resolve. Or worse case one wrong wire could toast you ECM and/or Gauge cluster. So in the long run buying a complete Max Harness will save you time and money and much grief! You have enough work ahead of you to not add the possible issues of splicing a harness just because your being cheap lol! Just sayin.
Whatcha plans for the shocks now? Cut 2 inches of travel off the rear shaft?
Discussion Starter #26
Not really about being cheap, its about i have 100% confidence that I CAN and WILL NOT have any issues. I put a R1 engine in a RZR800 years ago and built my own harness with ZERO issues.
Marine adhesive heatshrink crimps and a good wrap in quality tape will prevent those wire junctions from corroding. Looks like a great project!
I assume you’ll be changing spring rates with the heavier chassis and load capacity.
I have done similar however its a fair amount of work and using an off the shelf max harness would save you time. I used to make everything.
Nowadays if I can buy it, I do. To each his own I suppose.
I can't believe that old frame didn't have any cracks. Makes me feel better about mine. Might have to check this project out sometime when I'm in the area for a beer at my favorite bar in your neighborhood.
I have the unedited photo of Mega's shop!
What the hell is he watching on that TV screen!
Discussion Starter #39
my parts list
QTYprojected cost
2017
1705013059Central Skid Plate179.99
1705009505White LH Front Fender | Model White91.19
1705009506White RH Front Fender | Bright White91.19
1715003933Front Skid Plates | XRSDPS Package75.99
1705011368LH Rear Central Lateral Panel41.59
1705011369RH Rear Central Lateral Pane41.59
1705013095LH Latch21.05
1705013096RH Latch21.05
1705011579LH Central Cage Trim20.27
1705011580RH Central Cage Trim20.27
1707900492Middle Console13.19
1707900568Rear Console13.19
1707900575Passenger Handle20.79
1707900497Middle LH Lateral Dash Panel41.59
1707900498Middle RH Lateral Dash Panel41.59
1707900571Rear LH Lateral Dash Panel41.59
1707900572Rear RH Lateral Dash Panel41.59
1707900493Side Panel Cover34.39
1715005785RH, Lateral Panel Cover33.53
1707900495Left Floor37.59
1707900496Rear Right Floor37.59
1705402026Drive Shaft Ass'y148.19
2709200664Radiator Tube25.58
2709200709Hose51.18
1705601571Rear Flexible Hose | Model X3 Xrs123.99
1705014684Central Hood43.31
1707900569Rear Consol Support12.39
1707900573Consol Support19.99
1707900570Rooting Support29.59
2018
1705013098Black LH Central Door Trim20.79
1705013099Black RH Central Door Trim20.79
2707900653Foam | Package XRS133.74
2020
1715006606Deep Black, Frame (4 seat)1903
1707800859Silencer Intake Ass'y95.99
1707800856Hose25.59
1514052924Norma Clamp Exhaust emission component8.96
1707800819Radiator Support74.39
1707800840Intercooler Ass'y523.99
shipping600
rear seats0
rear seat belts0
amazon150 nut certs20
amazonnut cert tool50
Salstrip and paint500
S3S3 gusset kit225
LSRLSR gussetts318
TMWTMW gussetts200
WellerWeller racing gussetts48
A&AA&A gussetts30.64
UTV Distribution cage bungs197
2017 705402115 front drive line147.99
705401354 boot kit wheel side front35.87
rock guards
door hinge plates
rear seat sliders
6594.77
I would consider get the 3/8" Factory UTV skids. They hold up better than the stock one, if you plan on doing more trail and dirt riding.
