I've checked and all they say is the max psi for the tires which is 22psi. I'm going to start with 20psi back tires and 18psi fronts and work my way down. I'm concerned about running too low of psi on pavement and wearing the tires out prematurely.Well, what does Tusk recommend? PSI is so subjective.
Yeah, I can see that. Might be a bit high with 20 / 18? But it's one of those try it and see deals.I've checked and all they say is the max psi for the tires which is 22psi. I'm going to start with 20psi back tires and 18psi fronts and work my way down. I'm concerned about running too low of psi on pavement and wearing the tires out prematurely.
We had 8 ply Terrabites on our '15 OG XDS Turbo car, and currently have 10 plys on our '20 XRC Turbo RR car. However, beings these 2 cars/suspensions are night and day different, I couldn't begin to advise.Has anyone had set 8ply and 10ply tusk Terrabite tires? If so what was the difference between the two sets? Here in Lake Havasu Az the train is like gravel with washboard with rocks. I am thinking that 8 ply would be better for the washboard but am concerned about the rocks.
Thanks for the honest opinion it is greatly appreciated. Have you had any problems with the 8ply tires that you think you would not have had with 10 ply?We had 8 ply Terrabites on our '15 OG XDS Turbo car, and currently have 10 plys on our '20 XRC Turbo RR car. However, beings these 2 cars/suspensions are night and day different, I couldn't begin to advise.
We use our machines from rock crawling to asphalt and everything in between. The 8 plys worked fine on the OG with 7/7.5 psi cold pressure... they usually get to about 10/10.5 psi warmed up. Never had any issues with tire pinch nor jagged rocks ripping the sidewall on them. I will admit that when crawling in rocks and high speed trails, my priority is to always pick a line that steers away from any embedded rocks that look to be a "sidewall ripping mofo"...Thanks for the honest opinion it is greatly appreciated. Have you had any problems with the 8ply tires that you think you would not have had with 10 ply?
