1 - 6 of 6 Posts
I replaced the factory eps with the tusk aftermarket unit. They said it could fit in same location as original under hood. Not so. Must put under dash . Also spline on rack does not gmhave a flat spot. I had to grind away one spline and then it slipped on. Otherwise not a horible experience. It does work . Instructions are so so but you can figure it out. Wireing was simple.
We’re you having problems with factory unit, or just trying to find something that works better?
yes, the factory one didn't work when i bought the car, then i replaced it with another factory unit but somehow the terminal got corroded and that didn't work, do i figured lets try to save a few buck and get the /tusk unit, /which seems good so far.
Do you notice any difference between factory and Tusk.
Out of curiosity, what price difference between the two?
tusk $589, factory $1600. Cant tell yet . I need to adjust alignment of shafts tomorrow. but it seems similar so far. i t
1 - 6 of 6 Posts
