Status
Not open for further replies.
21 - 40 of 68 Posts
Do you have one of these installed? If so, did you notice any change in throttle response or performance?
I've installed it, but I'm doing some work on the clutches, fitting a second fuel tank and some other stuff, so haven't had the chance to drive it yet.
Yes it did come with a prefilter cover for the intake, but not for the breather.
Thanks, please post when you have a chance to run it, so we all know if it works or not.
Yeah where are the results guys!
X2....need feedback!
it looks and sounds badass !
sounds like v-tec on a Honda with intake !
Do you have one? It's not in your signature??? If so, do you notice any added throttle response or power?
Anywhere from $375 to $435 depending on if you get a discount
no just from looking at the pics and they have a video of it on there maverick running thru the desert sounds badass !
It gave me 1 mph top speed So now I too out at 77mph and it feels like a little mid range but my tires are so beat who knows. It does give you a little more cab noise but I like it.
Do you have the stock exhaust?
Any difference in throttle response?
Yeah all stock performance other than the intake. It kinda feels like it may have gained a little bit but again my tires are screwed so it may be all in my head.
I can for sure say that I gained 1mph top speed and it holds right at 8,000rpm now where before it would hit about 7,950rpm for a second then back down
So you have been running it without any tuning or adjustments? Not sure 1mph is enough of a gain to be accurate. If it was 3 or 4 mph increase that would be definate.
No adjustments... To be honest I only upgraded bc the stock filter setup is terrible I wanted to switch to a cone filter to be sure it was actually filtering.
That is one reason I was wanting a different filter set up. I already have an exhaust so I would hope for a little more HP gain.
21 - 40 of 68 Posts
Status
