This intake will add maximum air flow and add horespower by letting your maverick breath..pm for pricing
I hear ya but shouldn't a $400 air box all ready have this designed into it? These boxes aren't waterproof and aren't designed to run snorkels, so there is a fairly good chance that you could get water in it at some point in time….u can install a jet ski drain plug for 99 cents ! and take u 30 seconds to drill it !
Thanks for confirming….glad someone could tell me.They have a drain hole in the bottom with a rubber insert that's supposed to act like a non-return valve.
Yes if your running snorkels then this intake is a bad idea. I would stay with the sealed box.I hear ya but shouldn't a $400 air box all ready have this designed into it? These boxes aren't waterproof and aren't designed to run snorkels, so there is a fairly good chance that you could get water in it at some point in time….
Is there any data or dyno numbers to support the claim of increased HP?This intake will add maximum air flow and add horespower by letting your maverick breath..pm for pricing
Do you have one of these installed? If so, did you notice any change in throttle response or performance?They have a drain hole in the bottom with a rubber insert that's supposed to act like a non-return valve.
