1 - 10 of 10 Posts
Does anyone know who's turn signal kit is in this video. It can be seen @ 6:57
Video
Discussion Starter #4
thanks,
I am interested in a signal kit, just not sure how much I need one, or if I need the column switch, or just a dash switch would be fine.
I use the dash switch. I wasnt a fan of the look of the column mounted one. I have no issue with the dash switch, I like that it lights up to show the signal is flashing.
Discussion Starter #6
I was curious if they made the led signal wire run through the blinker circuit so it flashed the switch light with the blinker.
After thinking about it further, for as little as I would use it the dash mounted switch would be alot better.
Off subject for Hollywood. Just as a matter of note, Ken Block stays in a Grand Design Momentum to reference the toyhauler thread.
1 - 10 of 10 Posts
