1 - 8 of 8 Posts
Anyone have a write up on removing the tranny? My mav has 370 miles and the output shaft bearings are shot... yay me!
I have a 2013 commander transmission with low hours that should work if you decide to go down that road...$1000 plus shipping
there was one on the FB page. pretty sure ya need to pull the motor to pull the trans
Administrator
I probably had seen the same one....mudders did a tranny swap at the races in 5 1/2 hours and managed to work in a lunch break. FYI, they pulled engine and tranny together.
Yes, the engine and trans come out as an assembly. If you never did it before I'd figure 6 hours out and 10 going back in. That's taking pics, tagging connectors, cleaning, wire tying everything back up and double checking yourself after every step. Now that I've done it I could probably do it in almost half that time.
I twisted off rear drive shaft on last ride (5min ride) and cracked trans casing. took in to dealer due to size of the job
1 - 8 of 8 Posts
