1 - 15 of 15 Posts
Plan on knocking out the greasing for the wheel bearing this weekend.
I was informed that the torque specs are:
Hub nut 184
Caliper bolts 37
Lug nuts 89
These numbers seems right. 184 for the hub seems like alot.
Machine is a 2021 Can Am Maverick X3 MAX RS Turbo RR Smart Shox
Hub nut 184
Caliper bolts 37
Lug nuts 89
180 is what the axle nut is supposed to be, as I recall - that’s what mine gets. 80 on the lug nuts, but I’m bad with remembering numbers…so I HAVE to round off…
Discussion Starter · #6 ·
Also you have to line up the cotter pin hole to the castle nut so it's get close to the number and align the holes...
Yeah I have a feeling this is going to be a joy. Have to break out the old hockey stick to hold the break paddle as well I suppose lol
Buy an online shop manual asap so you will know the torque numbers and understand your vehicle. The majority of us have them . Some people go up to 200 lbs on the axle nut.
I just use an impact gun and get the cotter pin in.
Ummmmm what ??? I use my fingers or a little hammer to tappy tap it in, after the proper torque is applied
Hub nut 184
Caliper bolts 37
Lug nuts 89
There is a thread on here with all the torque specs
Reactions: Dempsey
I just run it down with an impact gun and put the cotter pin through lol. I really shouldn’t be on here when I’m half awake
1 - 15 of 15 Posts
