The first time I dropped the hammer on pavement it lurched to the left and just driving normal it wanted to pull to the right.I found the tire pressures off so that fixed the left/lurch part but still wants to pull slightly to the right under normal driving.I suppose I need to fine tune align.I'm a sledder from way back and one thing I know is that you need to toe out the skis or your sled will dart all over the place if you don't.I did a search and see PoPo. recommends toe out on the front wheels makes sense so that's what I'm going to do four the fronts.Just came back from checking the toe it seems all four are toed out but its hard to get a good reading.Heres a pic of how I did it. The pic isn't that accurate,there must be a better way.BRP says rear should be straight,no toe right?
