1 - 2 of 2 Posts
2019 x3 Xds R
Morning. Looking for some input on tire size and what is recommended.
Ordered some walker legacies in 15 x 7 x 5+2 off set. Going on my 19 rds turbo r (64”).
Looking at mrt race tires in 30 x 9 x 15 or 32 x 10 x 15.
I’ve only had the stock bighorns up to now. Just want to see what others recommend for tire size. Plus any benefits/negatives from tires being the same size?
I ride mostly tight wooded trails, northern Michigan type stuff. AA tuner going on with the new rims (stage 2) will be going stage 3 (inter, exhaust, plumbing, from treal) in the future. No plans going past 3.
Just want to make sure I’m not making a mistake or over looking something.
with stock offset wheels those 32 will probably rub in the front at full lock a bunch
you will need wider offset than the oem wheels for 32 tires
wheels like 2+5 are needed even then they may still rub a little
32s fit the 72 wide cars better
1 - 2 of 2 Posts
