41 - 50 of 50 Posts
Alex - Let me know what I need to do to get that tab as I am running your high misalignment spacers now.....
Thank you sir.....do you think I will be able to get the bolts off without cutting them to install the tabs? I torqued the bolts to 164ft/lbs and used the red Loctite on them!
Impact, Heavy...Impact, lol.
I guess we will find out :shocked:
Thanks Alex.....I assume, you would recommend replacing the Nyloc nut after removal....correct?
Thanks Alex.....yea, your right..sorry for the confusion.
Bumped this old thread as it is the only one I found that is useful for a newbie to adjust tie rods. I used a 1/2" piece of all thread cut to 47.5" then put a 1/2" nut and rod coupling on each end to get an accurate measurement. I set the toe to 1/16" in.
41 - 50 of 50 Posts
