Got my TurnKey (OEM replacement) tie rods primer & painted, and installed today. However, one of the tie rods was approx. 1/8" longer??!! Luckily there was enough adjustment in the ball-joint end to accommodate.
For those of you who have already replaced yours... what's the best way to make sure the wheel alignment is set properly? I swapped out the tie rods without moving the wheels and tried to put everything back to the original position (except for the slightly longer tie rod). Any suggestions?
