61 - 80 of 105 Posts
2018 Maverick X3 Max X rs Turbo R
Thanks Craig, the Switxh Pros unit has been received and I'll be installing it this weekend. Great price and service, thanks!
Sent from my SM-G998U using Tapatalk
How waterproof is the switch panel itself?
I plan to mount using the SSV plastic atop the center column above the switches.
It will get wet and I ride in SE mid and water mostly.
Official Site Vendor
Discussion Starter · #64 · (Edited)
The switch panel is IP 67 rating. Good for splashing and such. If your going underwater it may not work.
Switch Panel Specs:
  • RGB Backlighting provides unlimited color options, allows for exact matching to factory dash lighting
  • Built-In Bezel Style Switch Panel enclosure measures 4” L x 2” W x .375” H ; includes concealed mounting hardware for factory-look installation
  • Orange LED switch indicators
  • 100 User Selectable Legends
  • IP 67 rating
Power Module Specs:
  • 8 Outputs: 4 rated @ 35A, 4 rated @ 20A
  • 125A maximum rating
  • Waterproof and Solid State
  • 6”L x 3”W x .5”H (excluding connectors)
  • LED Input Status Indicators for easy troubleshooting
  • Underhood rated 125° to -40°C
Switch Panel Specs:
  • IP 67 rating
Power Module Specs:
Craig, I'm installing the one we purchased from you... and I'm honestly wondering why I didn't buy the SP-9100 sooner! The wiring is so much easier. Here's a picture with the work in progress. Note that I worked with Extreme Performance to design and have them fabricate a custom center dash that includes the Switch Pros panel, a mount for the Garmin Overlander, and a mount for the Rockford Fosgate PMX-8DH. You can't see it, but I was able to mount the PMX-8BB just inside the custom center dash on a sheet of aluminum I fabricated and attached to the frame. The two open spots are for the PCI Race Radios car-to-car radio and Trax+ intercom. More pictures coming when everything is done. Thanks for the great price on the Switch Pros!
268450
Reactions: OffRdX
Discussion Starter · #71 ·
SWITCH PRO STEERING WHEEL MOUNT BY ASSAULT INDUSTRIES
Art Font Automotive decal Emblem Symbol
Discussion Starter · #76 ·
Newest version:
SP9100-D SP9100 8-Switch Panel Power System (D)
Rev. 1; RGB backlighting (rev. 1.1; 11/29)
Dimming for lighting outputs
External trigger to activate up to 2 outputs
Battery Voltage display on app screen
Four 35A circuits and four 18A circuits
Eight user-programmable switches
Discussion Starter · #79 ·
Newest version:
Discussion Starter · #80 ·
Switch Pros SP-9100 8-Switch Panel Power System from Pro UTV Parts
Newest version:
