1 - 20 of 105 Posts
Official Site Vendor
Switch Pros SP-9100 8-Switch Panel Power System from Pro UTV Parts
Mount for Switch Pro
Automotive tire Automotive design Bumper Vehicle Motor vehicle
Newest version:
SP9100-D SP9100 8-Switch Panel Power System (D)
Rev. 1; RGB backlighting (rev. 1.1; 11/29)
Dimming for lighting outputs
External trigger to activate up to 2 outputs
Battery Voltage display on app screen
Four 35A circuits and four 18A circuits
Eight user-programmable switches
The Switch-Pros SP9100 is a compact, solid state switch panel power system, capable of flowing 125 amps of continuous power. With a total of eight circuits, four rated at 20 amps each and four rated at 35 amps each, you can power all types of 12 volt accessories. The touch panel is weather resistant, and measures only 2”x4”. The panel includds a Bluetooth transmitter, which allows you to program AND operate your system from any wireless device. Programming options include output Dimming, Strobing, Flashing, Master-Slave functions Memory, Auto Power-Up, Momentary, Battery/Ignition input, and a multitude of other options. RGB technology allows you to choose ANY backlighting color you desire. The kit also includes 100 switch legend options, so you can customize the panel to your specific accessory set up The under-hood mounted power module is waterproof, and ideal for all applications. It is COMPLETELY SEALED, and rated to 125 degrees Celsius. It has a 3”x6” footprint and comes with a fused power cable, and both harnesses which communicate with the touch panel. THERE IS NO BULKY RELAY BOX with our kit, as we utilize technology that allows us to control each circuit with a microprocessor. No need to worry about over-current or over-temperature conditions if your system sees a short, or one of these conditions, it shuts down and attempts to reset. No fuse to replace and no worry of fire hazard
Now available from Pro UTV Parts
Here is the Forum code with FREE SHIPPING SwitchPros
PM for your best deal or order online:
https://www.proutvparts.com/collecti...l-power-system
249068
SWITCH PRO STEERING WHEEL MOUNT BY ASSAULT INDUSTRIES
Art Font Automotive decal Emblem Symbol
1 - 20 of 105 Posts
