You must not be running hard enough to shake it loose, if you take the right dash piece off the tank is right there I think theres a brace to remove to access the fuel pump pull it out of the tank and see if the arm is bent or? Thats not letting it move to show the fuel level
It’s part the fuel pump assembly. If you have an extended warranty, it should be covered..... mine was. No individual parts to fix, must replace entire fuel pump.Hope that helps. If no warranty, I would remove fuel pump and maybe you can fix it.....depends on what the cause is. Mine would read full until I had about 1-2 gallons left and it would then drop to empty/reserve......a little iffy if out on a long ride
Who's going this weekend? Johnson Valley June 3, x3 cars... Ed has demo shocks he can bolt on your car and you can take it for a spin. Or he can tune your shocks on the spot. Take advantage of this, he tuned mine and wow what a difference, well worth it.. he also has Walker Evans sway bar links...
So, I picked up a Rugged radio and intercom kit (RM-60 + RRP696) at the sand show. They told me it should be wired directly to the battery to minimize the chance of electrical noise. I get that, but I'm wondering if anybody has added an accessory triggered relay in-line, so the radio and...
Anyone have experience with can am's on snow tracks. I was thinking the x3 would be a kick in the ass out in the snow.
I added the OEM Glass Windshield and a rear windshield, I thought it might get hot so I found some Toy Hauler Garage vents in Black and thought they would work. I also added the Fourwerx Dash and it is truly awesome.
Check it out.
