1 - 13 of 13 Posts
Last night I changed my stock springs and weights to the epi. my question is I didn't notice the allen lock screw in the center of the primary bolt and I used a battery impact to take it off. I put it back on and torqued it to specs then realized it was a center lock bolt. Should I loosen the center bolt and then the main bolt and retighten it then tighten the center lock bolt or you think it will be ok if I never touched the center bolt. Let me know thanks
I think the center is to keep the nut locked from over tightening more so I think u should be ok !
ya I think ur 1 of the very few to take apart the newest clutch recall ,
hunterworks would be a good one to PM on that also !
Seems to me that the center set screw needs to be removed and re-torque the primary nut. Then put the center screw back in. Doesn't seem possible to attain correct torque with a locking screw already installed.
I don't know that for certain but if it was me I'd do everything possible to make sure it's right. If it comes apart it will be expensive.
Reactions: kroth1984
Here is the procedure…..
Auto part Automotive wheel system Tool accessory Diagram Vehicle brake
Vehicle Car Classic car
Text Vehicle Car
Reactions: LBSwank
Discussion Starter · #7 ·
Yeah I better undo it an reset it then . Also heavy when I said I didn't use a clutch puller I never nook out the stud I just slid it off of the shaft . And took the top hat of to Putin my weights
Good info there for sure. I was surprised there was no loctite on the tapered stud but there hasn't been any noise on clutch failure since last recall. I would guess 95% or more of any future clutch failures will be from incorrect installation.
Another forum member emailed it to me. I have the whole document in PDF format if you shoot me your email address, I will send it to you when I get home tonight.
Sent….let me know if you don't get it.
Does anyone know if there is a way to post a .PDF document on here? It would allow us to share documents much easier than converting to .JPEG...
1 - 13 of 13 Posts
