Does not make sense. Belt deflection is regulated by shims that limit closing in the secondary, does not have any effect on how much the secondary opens
Your theory would only come into play if the belt was to short or if you could change the distance between the primary and secondary like on a snowmobile
Exactly…so if you are not shimmed properly (incorrect belt deflection) you will limit the range of motion of your clutches. If too loose (too many shims) the primary will start out in a higher gear ratio (higher on the primary sheaves) like starting in second gear.
Think about it this way. When placing a belt in the secondary, the distance around the secondary (circumference) with 1 shim in it will result in a greater distance than if you had 2 or more shims in it. So you are compensating for belt width and length with the shims. So if not shimmed correctly, you will have the same affect as if you had your clutches too close together (too many shims =too loose) or too far apart (not enough shims = too tight) as you mentioned on a snowmobile.
Also, consider the fact that as your belt wears and stretches an becomes narrower…..you naturally loose top speed on the stock clutches because you have no adjustment for belt deflection to compensate for this. With an STM secondary, you do….the shims. So hopefully, this better explains what I am trying t point out. Belt deflection is just as important as proper weight placement in the primary. It is a tuned system and if you modify or change any of the adjustable variables (i.e. belt delfection, heal weight, tip weight, helix angle, spring rate…..etc) they will all have an impact on performance in different ways. Belt deflection will impact you affective gear ratio and possibly the ability to achieve full shift out……which equates to acceleration and top speed.
