1 - 2 of 2 Posts
STI’s newest extreme terrain tire – the Enduro XT/S – is a dual steel-belted 8-ply radial that gives owners superior puncture resistance and longer tread life. Adding to its durability, the Enduro XT/S has reinforced sidewalls and rim guards to protect against pinch flats.
The new tire’s tread pattern is a true multi-terrain design that delivers high-performance traction over a wide variety of surfaces. The Enduro’s carcass uses a wide contact patch for a smooth and quiet ride. These tires are also DOT approved for use on hard surfaces.
Features
Tread pattern designed for ultimate multi-terrain traction and handling.
Dual steel belts in an 8-ply radial design.
Reinforced sidewalls and rim guards for flat avoidance.
DOT marked to handle hard surfaces confidently.
STI Enduro Tire @ SXSPerformance.com
1 - 2 of 2 Posts
