** Now Shipping! **
NO RADIO NEEDED. This compact unit completely replaces bulky marine head units of old with a small, neat package that is completely weatherproof. The MRB3 measures just over 3 inches in width and only less than 1 inch deep due to a compact hide-away brain, so finding a spot in your UTV's dash to install it is a no-brainer.
The powerful yet compact MRB3 features Bluetooth, FM/AM radio, and an optional Auxiliary input making it the most versatile media controller you can find for your UTV, Jeep, Truck, or boat. The compact unit flush mounts on any flat surface, and only needs less than 1 inch of space behind the face. The weatherproof unit features a 2Ω stable amplifier that puts out up to 200W, powering up to 8 speakers with clear, crisp sound.
6 Preset EQ options allow you to fine-tune the audio to your liking, and a 4v RCA low-level pre-output means you can run it in conjunction with an additional amplifier and powered subwoofer. Included is a fully weatherproof wiring harness for the MRB3 to ease installation as well!
The controller features a large hyper-white LED backlit display designed to be visible in all conditions while controlling volume, track, and play/pause functions with glove friendly, backlit rubber-coated buttons. Includes an optional kit for 2.1 amp USB charging and 3.5mm Auxiliary in compatibility. Play any song, from any device, anywhere with the new SSV Works MRB3 Bluetooth Media Controller!
Specs:
- Bluetooth, Aux-in, FM & AM sources
- Compact control with hide-away unit for easy mounting
- Weather-proof durability
- 2Ω stable 200W max power
- Control volume, track, play/pause
- 6 preset EQ options
- 3.5mm AUX-in & USB charging
- Plug & play installation
- 4v RCA low-level preout
- Hyper-white LED back lighting
- 5' cable between controller and hide-away unit
SSV Works - Side by Side Vehicle Specialists
Specs:
